bullaka's avatar
bullaka
Router after c6300
I have a c6300. I also have a router after that. I use the c6300 network for my work wired and wireless. I have another router that is used for everything else in our house. I noticed WAY slower spee...
  • antinode's avatar
    antinode
    Apr 27, 2020
    > [...] I use the cable and port that was connected to the computer for
    > the modem. Then I used a different port and cable for the computer.
       Ok.  And is that "different" cable tested or known-good?  The LED
    indicators on a C6300 may not be good for much, but can you find any
    information about the physical link rate at ADVANCED > ADVANCED Home :
    Internet Port : Show Statistics?  Or from the other router/WAP, or the
    computer OS?
       Blame assignment is Job One.  Is the hardware working as expected?  A
    bad cable or port could limit your speed to 100Mb/s.  This whole
    diagnosis thing might work better if _both_ of us were putting some
    thought into it.
