luddite309
Jan 19, 2025Aspirant
Router based VPN
Hello all, So I've been wanting to set up a router based VPN for obvious reasons and recently read an article about using Wire Guard (they use Proton VPN as the example, and that also is what I'd lik...
luddite309
Jan 22, 2025Aspirant
On my Proton VPN web site (not within the program itself) there is a setup page where one ostensibly can set up either OpenVPN or WireGuard, though. It's all one needs to download the proper config file for whatever platform one is on, including "router". Of course, and with some foreknowledge of problems I've had in the past when attempting to do something akin to this that caries risks, I am hesitant to try, and may go with a software solution instead. That works for my pc and phone and tablet, but not the other connected devices.
Kitsap
Jan 22, 2025Master
luddite309 wrote:On my Proton VPN web site (not within the program itself) there is a setup page where one ostensibly can set up either OpenVPN or WireGuard, though. It's all one needs to download the proper config file for whatever platform one is on, including "router". Of course, and with some foreknowledge of problems I've had in the past when attempting to do something akin to this that caries risks, I am hesitant to try, and may go with a software solution instead. That works for my pc and phone and tablet, but not the other connected devices.
Good luck!
- luddite309Feb 02, 2025Aspirant
Just as a follow up, purchased a subscription to Nord VPN today, using it so far on Windows and my Android phone, seems to work very nice with little loss of speed (at least while I'm connected to New York), and while I probably could get it to work on the router, at this juncture not willing to take the risk. Really, the only other device that won't be able to use it, I think, is my one tv. I may see if it does have the ability, I can download apps to the tv.
Anyway, have a good evening.
