Hawk944T
Jan 20, 2020Follower
Router blocked by Netgear Genie message requesting new password
Have older Netgear router that has worked fine. Now blocked by a message from routerlogin.com that requests Admin Accout Settings with a password be created. Is this a legit request from Netgear or...
oldman2
Jan 20, 2020Aspirant
I've been doing a lot of factory resets and a screen like that always shows up and also asks 2 questions.
antinode
Jan 21, 2020Guru
> Model: C6250|AC1600 WiFi Cable Modem Router
Is that accurate?
> [...] Now blocked by a message from routerlogin.com that requests
> request from Netgear or a sham?
It's not any kind of "request from Netgear". "routerlogin.com"
normally points to your own (modem+)router, not to some outside-world
web site (legitimate or not). If you're in any doubt, then disconnect
the cable which connects your (modem+)router to the outside world.
> [...] Can the blocking message to removed or worked around, without
> inputting any info?
Probably not. I'd guess that the idea was to make it harder to gain
access to your device using the default password. Do you believe that
leaving the password as "password" will make it more secure than
selecting a different password?
