mike466
Sep 06, 2019Aspirant
router for cox gigablast
my modem is arris sb8200 which router works well with cox gigblast? looking for a basic, easy to setup router, that is not slow and works well with cox gigblast speed tried my linksys ea6500 ro...
Sep 06, 2019Guru - Experienced User
If your asking about NG routers, R7800 series or higher. R8000/9000 should support near 900Mbps on the WAN to LAN. NGs XR450/500 as well. I know my XR450 gets 900Mbps on the WAN to LAN side. I tested the XR700 and the one I had failed the WAN to LAN test. Hopefully FW will fix that.
Please post about this also in the Nighthawk router forum:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
