Nontechy4
Aug 11, 2020Tutor
Router hacked? Nighthawk C7000v2
I have a netgear modem router and only have my laptop connected. I was viewing router log and getting ready to save copy and this image popped up. It shows an Arris router, a genie media server and tw...
Aug 13, 2020Guru - Experienced User
The Arris is a TG model modem, which is it own cable and router combo unit. Are you sure you have C7000 modem router unit?
The PC seems to indicate it's connected to this arris modem and not a C7000 modem.
Nontechy4
Aug 14, 2020Tutor
I do not own an ISP router. I purchased my own. I did not set up a network and have my settings for not visible. I checked the visible box and saw this. I do not have a media server. During this login I had a laptop connected to router. No loT devices. It was alarming to me. I’ve been researching to see if my router is an access point but my settings show router mode. I have not been able to view this again. I am concerned with hacking.
Any input is appreciated.
Thanks again.
Thanks again.
