erink883
Oct 10, 2020Aspirant
router log in
when you're trying to log into your routgerlogin.net to look at your settings/connected devices/etc, does it make you sign into your netgear account and then give you trouble like 3-4x's then finally...
Oct 11, 2020Guru - Experienced User
Has a factory reset and setup from scratch walking thru the setup wizard been performed?
Try using different browsers for this...
