flj2
Apr 06, 2017Follower
Router login
When I go to routerlogin.net I can not log in. I try using the user name "admin", and the default password, "password" without success. While I don't think I have changed anything I may have. Is there any way for me to log into my device and update the firmware?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Flj2
You may need to factory reset the unit by holding the reset button for 10 seconds then you can log into the unit with admin/password. If you do this you will lose all settings and have to set it up again.
DarrenM
