khkim
May 05, 2016Follower
Router mode is always "no"
Symptom: Router only allowed one device connection in each time rebooting router. This symptom started from 5/3/2016. ISP is Mediacom. I did following steps. I reboot router several times. ...
DarrenM
May 06, 2016Sr. NETGEAR Moderator
Hello khkim
Have you tried to do a factory reset buy holding the reset button on the back for 10 seconds? also you may want to contact your isp there system could be sending the modem a bad config file may want them to send some signals and reboots to the modem.
DarrenM
