andy792
Sep 11, 2017Tutor
Router not giving off wireless signal
This is the second modem/router that I have from Netgear. I sent the first one back through their RMA process and they sent me another one. The issue with the first one is that it would not broadcast...
andy792
Sep 14, 2017Tutor
My ISP is Spectrum and they said there is no WIFI OPT OUT CODE. They said that Netgear has to check the settings.
ErnestTheGreat
Sep 14, 2017NETGEAR Employee Retired
andy792You should ask Spectrum why is it that when your device is reset to factory settings without coaxial cable being connected that your WiFi works perfectly fine and only disappears once you connect the coaxial cable and connect to Spectrum internet service?
The easiest way to confirm if the Spectrum is causing the issue is to rest device to factory settings and power it on without connecting the coaxial cable and then once you verify WiFi is working connect the coaxial cable and see if it disappears. If the WiFi disappears when your modem connects to Spectrum’s service then the problem is caused by the configuration file and the parameter that is being added to tell the non-Spectrum issued modem to disable WiFi and operate in modem only mode.
- andy792Sep 14, 2017Tutor
Would I get an internet signal if the coaxial is not connected? Or do you just mean that I'll be able to see the network on my network list?
I think I understand what you are saying to try. When I reset the router by holding the reset button, should it be connected to my computer?
- antinodeSep 14, 2017Guru
No. It'd be magical if that worked.
> list?
Yes. At least, a wired connection should let you use a Web browser
to deal with the router's Web interface. If so configured, a wireless
connection to the router should work, too.
> [...] When I reset the router by holding the reset button, should it
I know nothing, but I wouldn't expect it to matter. It should work
with nothing connected. Two tries should exhaust the possibilities.- andy792Sep 14, 2017TutorI just tried this and I'm seeing the wireless signal but it's done this before when I tried resetting the router. It usually only lasts for a little while. I'll check tomorrow and if the signal is still broadcasting, then I'll call spectrum again and see what they have to say.
