armenis
Aug 14, 2020Follower
Router ping propping
Hello, Just got new Netgear C700v2 router and configured it. IP: 192.168.0.1 After few hour work the ping is dropping perioically. Reply from 192.168.0.1: bytes=32 time=1ms TTL=64 Reply from 192...
Aug 17, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Was the ping via wired or wireless?
