JNiznik
Nov 23, 2015Follower
Router Re-boot Required Every Time I Attempt Wireless Connection
I have a CG4500BD combo modem-router made for Cox Communications. If I turn off my smart TV or my wife's laptop, they will not connect wirelessly (with error "waiting for IP address") unless I power ...
DarrenM
Nov 24, 2015Sr. NETGEAR Moderator
Hello Jniznik
It sounds like some type of Ip conflict happening with these devices. I cant find much we can do in the settings of the modem to prevent this from happening as these modems are locked down and supported by Cox you may want to swap it out at one of there stores for a different one.
DarrenM
- ps5725Jan 23, 2016Aspirant
I have the same problem and did swap out for a new router. I am still having problems with the new router. I have also downloaded the adapters, to no sucess any help. Will a different brand work with COX? This is so irritating I could throw the modem out the window.
