MitchT
Aug 22, 2019Aspirant
Router reset and now shows factory network names and passwords
C7000v2 Router reset and now shows factory network names and passwords I came home and noticed my internet was out. I expected it was a Cox issue. An hour later, and after all the fixes f...
Aug 22, 2019Guru - Experienced User
Anyone have access to the modem and possibly hit the reset button in back? This would be the only reason. Or if they got into the modems UI and did a factory reset here.
MitchT
Thanks for the reply.
No one has access to the router except me -- and no one had access in the two hour window that I was gone before I noticed the problem. Wondering if a power surge could cause this?
- FURRYe38Aug 22, 2019Guru - Experienced User
It shouldn't.
You might try this. Set up the SSID and PW again. Get the modem set up as you like. Do a save configuration to file.
Simulate a power outage by pulling the power cord from the wall out let, leave off for 30 seconds to 1 minute. Plug back in. Check the SSIDs. If they revert back to default values, I recommend contact NG about this.
