Retired_Member
Sep 25, 2020Router Reset Itself
Hey all! Model: Nighthawk AX6000 CAX80 Firmware: V1.1.0.41 So had a weird issue this morning, woke up to everything on wifi not connecting but stuff connected via ethernet worked. So I went ...
Sep 25, 2020Guru - Experienced User
I haven't but it could have been the device either updating its firmware from netgear or from your ISP.
The CAX80 is the only device currently on the market with firmware seperate for the modem side to the router side. So maybe that's why.
Retired_Member
Sep 25, 2020So i double checked and I have the latest firmware from Cox CM: V1.02.08. So I don't know if maybe it wasn't updated and last night it tried to update and hit a speedbump?
- dadabunchieSep 30, 2020Aspirant
I also had that issue this morning. The gateway reset itself and went back to asking for a password. I've had it happen before so not the first time. Spectrum is my provider and I'm on the latest Modem/Gateway FW version as per Netgear.
- FURRYe38Oct 02, 2020Guru - Experienced User
I would setup the modem. Then do a backup configuration to file for safe keeping.
