jollygirl
Feb 13, 2016Initiate
Router suddenly can't connect to internet
Greetings! We've had this router for a few years and it has worked without issue. Yesterday, it went on the fritz. When ethernet plug goes straight into modem, we have internet. As soon as I s...
DarrenM
Feb 16, 2016Sr. NETGEAR Moderator
Hello jollygirl
I sent you a PM about the issue.
DarrenM
- KuchcickFeb 16, 2016Aspirant
I have the same problem with my wndr3400v2. Could you assist me as well?
- jollygirlFeb 17, 2016Initiate
Kuchcick - mine is going again. I can tell you what I did, but being tech-limited, I don't know if the same solution will work for you.
Are you able to get to http://routerlogin.com?
