UnderPressure
Nov 21, 2018Star
Router wifi settings gone after power outage
After a power outage, my Nighthawk router's wifi settings were gone and only I found default Netgear SSID's. I was able to log into the router with my admin password and other network settings seem t...
antinode
Nov 21, 2018Guru
A typical power failure is seldom a clean off-on event, so some
device confusion is possible.
> I had to completely redo all my wifi settings. (create SSID's,
> security settings, guest wifi, etc.)
ADVANCED > Administration > Backup Settings
> How do I prevent this issue the next time the power goes out [...]
That may be difficult. Better power conditioning (as from a UPS)
might help.
> [...] or when I have to unplug the router? [...]
Is that enough to cause the problem?
> Is this a known bug?
That depends on how you define "bug".
- dorcseMay 23, 2019Guide
This issue is not power condition or spikes. It happens when power is removed and then restored.
- myerswMay 23, 2019Master
If you want to prevent these issues, get a UPS!
While a surge suppressor will help some with spikes a power outage may also have a power sage, spikes and other things happen. A good UPS will isolate you from these issues. I have my modem and router both on a UPS just for this reason. For what a router needs they are not that expensive and frequent power outages could in some isolated cases damage the router. I have a whole house surge suppessor, but know that will not protect the electronics like a UPS will.
- dorcseMay 23, 2019GuideWhile a UPS is good to have, it should NOT be a necessity. The router should NOT lose all its settings due to a simple power interruption.
