UnderPressure
Nov 21, 2018Star
Router wifi settings gone after power outage
After a power outage, my Nighthawk router's wifi settings were gone and only I found default Netgear SSID's. I was able to log into the router with my admin password and other network settings seem t...
IrvSp
Nov 22, 2018Master
UnderPressure, along with what antinode said, I don't think it was 'normal'. Normal in the sense that losing power should have that happen. The settings and even the F/W is held in NVRAM... that should not be cleared at all with the general loss of power.
It is quite possible that there was a power spike or drop prior to the loss of power. It is possible that that caused some NVRAM to be reset even or just modified.
I'd suggest NOT saving the configuration at this point. I'd RELOAD the Firmware with a new copy first, then do the RESET or CLEAR NVRAM and then re-enter manually all your settings.
I'd think either the power state caused your problem, and you might not have noticed or be aware of all the implications due to that or you have a h/w problem if the NVRAM can't hold the contents without power.
lastdojo
Nov 30, 2018Initiate
I have the exact same issue. Power goes out, wireless configuration is erased. Admin password remains the same. WIFI goes open BTW, so after a power outage my entire network is exposed. This is not a power issue at my house. I have another NightHawk r7000, and it has never ever done that. Netgear has to investigate this.
- IrvSpNov 30, 2018Master
So did you report it to them? This isn't the place to do that, use SUPPORT, login, MY Support and report it.
- UnderPressureNov 30, 2018Star
I just reported the issue on My Support. IrvSp thank you for letting me know where to report the issue.
- MagicalropeOct 07, 2020InitiateHmm thought this is the place to ask how to fix issues. Also that was very rude.
- stefaniewDec 10, 2020Initiate
I had the same problem. Third 5ghz was no password and default name
- Canman_JACDec 11, 2020Initiate
Easiest fix. I replaced it with a Syn ology router
