UnderPressure
Nov 21, 2018Star
Router wifi settings gone after power outage
After a power outage, my Nighthawk router's wifi settings were gone and only I found default Netgear SSID's. I was able to log into the router with my admin password and other network settings seem t...
lastdojo
Nov 30, 2018Initiate
I have the exact same issue. Power goes out, wireless configuration is erased. Admin password remains the same. WIFI goes open BTW, so after a power outage my entire network is exposed. This is not a power issue at my house. I have another NightHawk r7000, and it has never ever done that. Netgear has to investigate this.
IrvSp
Nov 30, 2018Master
So did you report it to them? This isn't the place to do that, use SUPPORT, login, MY Support and report it.
- UnderPressureNov 30, 2018Star
I just reported the issue on My Support. IrvSp thank you for letting me know where to report the issue.
- MagicalropeOct 07, 2020InitiateHmm thought this is the place to ask how to fix issues. Also that was very rude.
