UnderPressure
Nov 21, 2018Star
Router wifi settings gone after power outage
After a power outage, my Nighthawk router's wifi settings were gone and only I found default Netgear SSID's. I was able to log into the router with my admin password and other network settings seem t...
UnderPressure
Dec 11, 2018Star
I unable to replicate the problem by turning on/off the router as well as moving the router to another power outlet. I also turned on/off the wifi button. The power outage was several hours long so it was likely the memory not being able to hold its data as you stated IrvSp.
BTW, my router IS connected to a high-end power conditioning system for our media center. Unfortunately, my UPS died in the last power outage so I didn't have one connected during the last power outage. I just need to install the new UPS (CyberPower CP1000AVRLCD) ordered during Black Friday. Any suggestions for how to connect a UPS when there is a power conditioner in the mix? I'm thinking I should just skip the power conditioner.
(Support team closed my case before I could respond so I just opened up another case today.)
antinode
Dec 11, 2018Guru
> [...] The power outage was several hours long so it was likely the
That's not what he said. Most likely, it's not a question of how
long the power stayed off. (Try it for a few hours. Or
days/weeks/months/years.) The likely hypothesis is that there was a
transient (surge, spike, whatever) around the time the power was lost or
restored, and that transient is what caused the data corruption/loss. A
hardware problem is much less likely, but very easy to test.
> [...] a high-end power conditioning system [...]
That tells me approximately nothing about that gizmo.
> [...] Any suggestions for how to connect a UPS when there is a power
> conditioner.
Ask someone who knows something about your (unspecified) "a high-end
power conditioning system"?
