UnderPressure
Nov 21, 2018Star
Router wifi settings gone after power outage
After a power outage, my Nighthawk router's wifi settings were gone and only I found default Netgear SSID's. I was able to log into the router with my admin password and other network settings seem t...
jonniego
Jan 05, 2020Initiate
Same issue here. I reset my cable modem and router once/day. I have used always used a timer to shut off my cable modem at 4 am and turn back on at 4:01 am, then use a second timer to shut off my router at 4:15 am and turn it back on at 4:16 am. I never had any issues until I bought the X6S at Costco yesterday. This morning my settings were erased, and the router was back to factory. I am taking the router back today.
I am not very impressed with Netgear. This is my second router in a week. I spent 2.5 days trying to get the new AX12 router to work, and finally, Netgear support said they believe it is a faulty router and to return or replace. I returned the $444 router to best buy and bought the $150 X6S at Costco. :)
- Lanteck00Jan 16, 2020Initiate
Same issue. Power has nothing to do with it. Loss of settings has occured when rebooting the router from the admin screen. After the reboot all defalt settings have been loaded. The unit makes me log into my account at Netgear, then I am told I cant buy a contract, then I have to attempt login to the router several times, and finaly get the the admin page so I can restore my setting from the backup file. I should have done a little more research before buying a Netgear product. Their support is very poor. I am going to Amazon to leave feedback on my purchase, not going to be very good.
Dumping this unit and purchasing one that doesn't make you have an account at Netgear to install. This is as bad as Microsoft and Windows 10.
- wiiNinjaFeb 14, 2020Guide
Same issue for me with a C7000v2, and power loss/spikes have nothing to do with this. I had to cycle power to the device and it happened. This will NOT work for me because what if I'm not home and there's a power outage? I will be out of internet in my house until I get back (could be days or months before I can restore the config settings). In the mean time, I rely on the internet for both home automation and home security, and an incidence like this would leave all of that dead in the water. This is a deal breaker. I had owned many Netgear products in the past, but this one really shake my confidence in Netgear.
- Canman_JACSep 01, 2020Initiate
I also have similar problems with my X6S router purchased at Costco. In my situation, a UPS keeps it powered during brief power outages, but when the ISP (CenturyLink) goes down for an extended period of time, the router loses it's wifi settings. Of course, this only happens when I am 1200 miles from home. An Orbi, at another property, never does this and it is connected to Comcast with frequent outages.
- hokieinidahoSep 01, 2020StarSince having ditched Netgear and replaced with Ubiquiti Unifi I haven't had issues or even had to reboot since June's installation. The only regret is not having done so earlier!
- GBNSep 13, 2020Initiate
I have the same problem after the newest update pushed to my router it's losing the setting. As said in other post it's not tollerable as I have secuity in through my router and this has shaken my confidence in netgear. I'll be looking into another brand of router if this is the response given by Neatgear. Of course they never heard of the 10 others rule when not addressing an issue. I really had trust in this modem now I have to place my trust elswhere if they cannot rectify this issue.
I had and issue with a router just the other day and had to replace it so the customer felt confidence in my company. Now the bank is happy and I can be assured they wont drop our company. Hope Netgear get it in gear.
