UnderPressure
Nov 21, 2018Star
Router wifi settings gone after power outage
After a power outage, my Nighthawk router's wifi settings were gone and only I found default Netgear SSID's. I was able to log into the router with my admin password and other network settings seem t...
Coben67
Dec 14, 2021Aspirant
Nighthawk AX2700 WiFi Cable Modem Router (CAX30S)
I have been experiencing the same as many of you, power off restart or power outage and all my Wi-Fi settings are *poof* gone! I bought this router after a bit of research and on reputation. Apparently I didn't do enough research. Shame on me. I guess Netgear rep is worthless now.
Others have mentioned an OpenWRT fix, will this work for my AX2700? I really wish I could return it to Bestbuy.
- FURRYe38Dec 14, 2021Guru - Experienced User
Usually 3rd party FW isn't supported on modem gateways.
Have you been in contact with NG support?
Others have mentioned an OpenWRT fix, will this work for my AX2700? I really wish I could return it to Bestbuy. - hokieinidahoDec 14, 2021Star
Unifi all the way baby! Never looked back. Well worth the spend.
- FURRYe38Dec 15, 2021Guru - Experienced User
Has a full factory reset and setup from scratch been performed yet?
What FW version are you using?
Others have mentioned an OpenWRT fix, will this work for my AX2700? I really wish I could return it to Bestbuy.- Coben67Dec 15, 2021Aspirant
Reset - Yes. Although that shouldn't matter since I only purchased it less than 2 months ago. It lost all it's settings 3x, after the 2nd I did a complete reset to default settings.
Firmware 1.4.10.8No, I have not contacted Netgear support. 9 times out of 10 support will blame another entity. IE Microsoft will blame Dell, Dell will blame Microsoft and the end user is left holding the bag. Skipping the increased blood pressure, I asked the hive mind.
- FURRYe38Dec 16, 2021Guru - Experienced User
You should do a backup configuration to file for safe keeping. Reloading this would help bring back the wifi if that happens.
You need to contact NG support and let them know what your seeing. If NG doesn't know about these issues from users, then might not get fixed. NG doesn't watch these forums.
- JjoshrtcaJan 27, 2022GuideFurry, you keep saying the same thing. Reset. That’s not the problem. We’ve discovered the problem in this thread iirc. The problem is that Netgear used cheapo nand flash memory for their rom (on a FIVE HUNDRED DOLLAR MODEM ROUTER!) and it craps out if there are a lot of read writes like there would be with nas and ftp and verbose logging and all the other features you can’t use on this pos router! I turned those off on my THIRD buy and return ropa dope that I had to keep pulling at Best Buy to you know be able to work and take classes online and watch Netflix and look stuff up on the web and generally just LIVE in todays world without being out a modem router for however long the warranty process takes and the device works great now that all those read write heavy features are permanently turned off. Please stop telling people to waste time resetting their device. Netgear needs to recall this pos product and make things right!
- FURRYe38Jan 28, 2022Guru - Experienced User
Resets ARE and always will be a troubleshooting step for any kind of support problem. Its up to you users to try it out or not. It's also your resposibility to make contact with NG support and let them know what your problems are. NG doesn't have clairivoiance knowledge to know what is happening to users and there products. Not everyone has the same problem nor same configurations. All we do here is to help narrow down problems when usres post here in the forums as best as we can, which does include Factory Resets. If all troubleshooting has been exhausted here in the forums with no resolution, then users have to make contact with NG support and escalate it. If you read thru the thread and you don't find a solution and you see that it points to contacting NG support then you can presume that the issue can't be solved here in the forums. So you'll need to contact NG support:
https://my.netgear.com/support/contact.aspx
I post how I see fit!!!
And you don't need a modem router combo to get internet services. You can use a separate modem and router combination which for other users works just as well and offers better flexibility in managing your network and devices and the modem or router itself. Modem/Router combo units are a conveience product for those who may not want separate units.
Thank you.
