IvanPena
Mar 19, 2020Aspirant
RouterLogin C6300
I am trying to setup portforwarding for my computer, but when I try to login in to my router I get an error every time. I have tried using routerlogin.com, routerlogin.net, and the default gateway but every time I get an error that it can't reach the page. My computer is running windows 10 and is connected via ethernet, and I have also tried logging in with my phone, only to get the same error. I was able to install the Netgear Genie and login through that, but I can't access the advanced options of my router. Any help would be greatly appreciated. Thanks
try going to 192.168.100.1
- IvanPenaAspirant
I still recieve the "This page isn't working right now" error
> I am trying to setup portforwarding for my computer, [...]
Why? What is your "my computer"? How is it connected to the C6300?
LED indicators?Do normal Internet-access functions still work?
> [...] and the default gateway [...]
Which was what? And the IP address of your (unspecified) "my
computer"?If the management web site of the C6300 has died, and cycling the
power on the C6300 does not resurtect it, then you might try a settings
reset.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Troubleshoot"
and "reset".
