cmarti02
Oct 22, 2020Aspirant
Same 3 Repaeting Critical Errors in Event Log
CM1150V, Firmware Version V4.02.02 I keep getting the same 3 repeating Critical errors in the event log. About every 30 seconds. Inbound and Outbound lights are flashing Green. Any ideas what cou...
Oct 23, 2020Guru - Experienced User
jmoyta I'd recommend starting your own thread for individual help so we don't confuse advise to people.
thanks!
(make sure to include the logs and cable connections page)
jmoyta
Oct 23, 2020Tutor
I decided to add into this existing thread so as to reinforce that this exact same issue was occuring elsewhere, which may well indicate a systemic issue such as a firmware bug. My log entries and cable connection information is very nearly identical to those shared by cmarti02.
My hope is that any advise offered toward resolution will be beneficial to anyone else having this same experience.
For example, if we can discern that Firmware Version V4.02.02 was very recently pushed out by Comcast/Xfinity and if a prior known-good revision could be tested, I'm sure that would be beneficial to all involved.
- plemansOct 23, 2020Guru - Experienced User
Its fine to include that you're having this issue but I'd still start your own thread and include the info requested and a complete description. That way we can check your info/setup.
