Saint_Blaise
Mar 19, 2020Follower
Samsung ML 1740 to C7000 ReadySHARE Printer Not Working
I'm trying to get an old printer set up via ReadySHARE. The printer is a Samsung ML 1740 from 2003-04. I followed the instructions for setting up a printer on ReadySHARE and the printer does not appear in the USB control center. It works if it's directly attached to a PC. Is the printer simply too old to be conntected to ReadySHARE? Or, is there a setting in the modem/router may be deactivated that I should look at?
1 Reply
Ensure the printers FW is updated.
If it's not appearing in the RS feature on the modem, then possible that this printer isn't compatible since it's fairly old.
You may want to get a printer server with a USB to wifi/LAN connection adapter to help with this if you want this printer to be accessed by other devices.
