Basssix
Apr 23, 2016Aspirant
Samsung S6 connects to router but not internet
When I switched to xfinity I bought a C6300. I had problems with the first one not allowing my NAS to connect so I exchanged it for another one. My phone would connect to the router and work fine for ...
- May 03, 2016I have solved my issue by replacing the Netgear with a Zoom. It was the only one I could find that stated it would work with Android. Hopefully Netgear will get things straightened out.
Basssix
- DarrenMApr 25, 2016Sr. NETGEAR Moderator
Hello Bassix
Our engineers are aware of Samsung devices not working properly on wifi and working to fix the issue. I have read a workaround of using the guest network with no security then disable the broadcast of the SSID so others cant see to connect to it.
DarrenM
