Basssix
Apr 23, 2016Aspirant
Samsung S6 connects to router but not internet
When I switched to xfinity I bought a C6300. I had problems with the first one not allowing my NAS to connect so I exchanged it for another one. My phone would connect to the router and work fine for ...
- May 03, 2016I have solved my issue by replacing the Netgear with a Zoom. It was the only one I could find that stated it would work with Android. Hopefully Netgear will get things straightened out.
Basssix
DarrenM
Apr 25, 2016Sr. NETGEAR Moderator
Hello Bassix
Our engineers are aware of Samsung devices not working properly on wifi and working to fix the issue. I have read a workaround of using the guest network with no security then disable the broadcast of the SSID so others cant see to connect to it.
DarrenM
