Basssix
Apr 23, 2016Aspirant
Samsung S6 connects to router but not internet
When I switched to xfinity I bought a C6300. I had problems with the first one not allowing my NAS to connect so I exchanged it for another one. My phone would connect to the router and work fine for ...
- May 03, 2016I have solved my issue by replacing the Netgear with a Zoom. It was the only one I could find that stated it would work with Android. Hopefully Netgear will get things straightened out.
Basssix
Apr 25, 2016Aspirant
Good to hear. One odd thing is that my daughter has a c3600 that our phones work fine with. I have diabled the 5Ghz and it seems to be a bit better. If it dosen't get better I will have to replace it with something else.
