hxquero
Jul 26, 2021Aspirant
Samsung TV Plus being blocked by NETGEAR
NETGEAR CAX80 Firmware V.2.1.1.5 Samsung UN50TU700DFXZA Software Version T-KTSUA2AKUC-2016.1 Purchased Netgear March 24, 2021. I trusted Netgear and didn't hesitate to drop $400 on what th...
Aug 22, 2021Guru - Experienced User
Can you please use the Choose File button and post a copy of a screen capture of the error seen on your TV when it attemps to connect to the CAX80?
Is there a error code listed anywhere on this screen?
hxquero wrote:
I'm so over this! I purchased a $400 router and it shouldn't be this much hassle!! I went ahead and reset the router, reset the TV, then installed the new firmware and still same issue!! Now, after updating the firmware, I notice that the wifi connectivity reliability has decreased. I also see some errors in the router logs...I regret buying this router!! Wish I had purchased it at Costco so I could just return it!
hxquero
Aug 23, 2021Aspirant
I then updated the firmware and now the internet port status is yellow...
