johnsails
May 15, 2019Aspirant
SanDisk 256GB Ultra Fit USB 3.1 Flash Drive - SDCZ430-256G-G46
I cant get any of my USB thumb drives to work.
anyone use this USB drive?
thanks, I'd like to buy that for storage.
May 16, 2019Guru - Experienced User
I believe NTFS format should work for ReadyShare. Try both to see what best works for you. Also depends on size of drive. If large, then NTFS would be best.
