riordanrocha
Oct 12, 2024Aspirant
Satellite SSID different from Modem/Router... Help
Dear colleagues, I'm not experienced on this subject. Couple months ago I bought a Mesh system, RBK753S, but then I noticed that there was no Modem, so I bought a Modem CBR750 recently. When I in...
CrimpOn
Oct 12, 2024Guru - Experienced User
The correct thing to purchase was a modem that is compatible with your Internet Service Provider, not another Orbi router.
Are you using both the RBR750 router and the CBR750 router?
- riordanrochaOct 13, 2024Aspirant
Thank you for your information, I appreciated.
I'm not using both routers, I'm using the CBR750 only, and I'm trying to connect to two satellites. One satellite connects with no problem, but the second one is not connecting at all.
- FURRYe38Oct 13, 2024Guru - Experienced User
Make sure Any RBS750 series FW is loaded with v4 FW as the CBR FW. If RBS are loaded with v7 FW, this is not compatible with v4 FW on the CBR and can make RBS not connect:
