MY11
Mar 09, 2021Follower
Second Network, adding AX1800 to RAX200 via network switch GS308PP
Can anyone help me detremine how to setup a second network(AX1800) to my exisiting network(RAX200) using a network switch(GS308PP)? I have a nokia fiber modem provided by COX that feeds into my RAX200, currently. My modem does not have a second feed to connect my AX1800.
Initially, when I fed the modem line into the switch and connected both router and mesh, all heck broke loose and the switch alternated activitiy between the two routers. My brother suggested feeding the modem into my RAX200 then connect the mesh(AX1800) to RAX200 but the netgear app doesnt recognixe the AX1800.
Essentially, I have 32 devices on my current network and need to alleviate it.
Im clueless at this point and need yall to educate me on what to do. Thanks in advance!
I recommend you post over in the managed switch forum for this:
https://community.netgear.com/t5/Managed-Switches/bd-p/business-managed-switches
Good Luck
> [...] how to setup a second network(AX1800) to my exisiting
> network(RAX200) [...]Why? Is there some actual problem which you are trying to solve?
> alleviate it.Why? What's to "alleviate"?
> [...] using a network switch(GS308PP)? [...]
> Model: GS308|8 ports gigabits unmanaged switch
Which is it?
> [...] AX1800 [...]
"AX1800" is a speed, not a model number. Look for "Model" on the
product label.
> [...] I have a nokia fiber modem provided by COX [...]Has it an actual model number?
> activitiy between the two routers. [...]Because that was a bad idea. Typical residential service (like
yours, I assume), would allow you to connect one device directly to your
(unspecified) "a nokia fiber modem". That could be a computer, or a NAT
router (like your RAX200). Adding a network switch would not change
that.> My brother suggested feeding the modem into my RAX200 then connect the
> mesh(AX1800) to RAX200 [...]
That might be an improvement, but you'd probably want to configure
your "the mesh(AX1800)" as a wireless access point. The User Manual for
that device (whatever it is) should explain how to do that.Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "access point".> [...] but the netgear app doesnt recognixe the AX1800.
I use a web browser instead of any Netgear-supplied app. That's also
covered in the relevant User Manual(s).Configuring a router as a WAP will give it a new LAN IP address. By
default ("Get dynamically from existing router"), it'll get that new
address from (the DHCP server in) your main router (RAX200). Hence, an
"Attached Devices" report from your main router should tell you what
the new address of your router-as-WAP is. Point your web browser at
that IP address to talk to the router-as-WAP. (That might become clearer as you
do the mode change on the router-as-WAP-to-be.)
> I recommend you post over in the managed switch forum for this:Sounds to me like a mistake. The switch (whatever it is) is not the
source of your problem(s). (What you tried to do with it was.)
