SoniaT216
Dec 07, 2021Follower
Secured Wi-Fi but no internet
I am having issues with my Wi-Fi and this new modem:router. I am clearly connected because my streaming is working and my tablet. But when I check the internet connection it says Secured but no intern...
Dec 07, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Be sure WPA2 and AES is set for the security mode on the modem.
Forget the SSID profiles on your devices then re-connect to the SSID.
Thank you.
