corvairbob
Oct 02, 2019Tutor
seeing my cameras thru my c3700 modem/router and the r6300 router
ok you helped me with that c7000 modem/router that i found was not compatible with comcast in my area go figure. anyway so once more i tried to get the r6300 router and the c3700 modem to connect tog...
- Oct 03, 2019
Ok, glad you got it working.
For future reference, please post in this forum for your R series routerL
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
:smileywink:
corvairbob
Oct 03, 2019Tutor
ok i think i got it. turns out with the r6300 router i had to do a refresh on the ip address. this unit gave all my ewuipment new ip address. the c7000 did not do that, go figure. so now i'm resetting all my cameras and redoing the porting what a job this is becoming. but now they tell me i will have one more step for security as well. i don't know about that but if i do then great. after i goet this all done i will return with a update. never knwo someone else may have this issue. thanks
Oct 03, 2019Guru - Experienced User
:smileywink:
