XDM
Nov 25, 2024Aspirant
Seems IMPOSSIBLE to port open ports on a NETGEAR Nighthawk AX6 AX2700 (CAX30)
've been trying consistently for about over a month and change to get some ports opened on this modem router combo. no matter how many times i configure the port forwarding or port triggering or even...
Nov 25, 2024Guru - Experienced User
uPnP should be disable prior to configuration of port forwarding.
What FW version is loaded on the CAX30?
- XDMNov 25, 2024AspirantThe latest firmware is installed.
So UPnP is interfering with port forwarding?- FURRYe38Nov 25, 2024Guru - Experienced User
Yes. Long known that uPnP does most of the forwarding automatically. If any user or manual forwarding is needed, uPnP needs to be disabled first, then go in and configure forwarding rules.
- XDMNov 25, 2024AspirantI just tried disabling UPnP as well as a factory reset and it's STILL closed.
