xiewanjun
Apr 25, 2020Follower
Serial Number: 4F41727AA2C5C, My router is only blocking my website (bluebayjobs.com)
My router in only blocking bluebayjobs.com which is my website. All other websites are working normally. I have checked the hosting service, wordpress service, Spectrum. Everything are ok. S...
antinode
Apr 26, 2020Guru
> My router in only blocking bluebayjobs.com which is my website. [...]
What led you to believe that the problem is with your "My router"?
"blocking" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> I have checked [...]
"checked" _how_?
One typical cause for such reports seems to be that the web service
provider has blocked access from your (router's) IP address, for some
reason like too many log-in failures.
