pedz
Feb 21, 2022Guide
Set local DNS server
Netgear Nighthawk CAX30 (it isn't in the "model" list) It appears I can not set the DNS server to be local. My DNS (pi-hole) is at 192.168.1.2 but when I try to configure it, it replies that it ...
- Feb 22, 2022
log in through the gui then go to the advanced tab---->advanced setup---IPv6
from there you'll be able to change the ipv6 dns
Feb 21, 2022Guru - Experienced User
I've got a pihole and ran it on my cax80 so it should be pretty similar.
did you set it up in both the standard internet setup page and on the IPv6 page?
do you have a screen snip of what you're doing and the error? that helps.
pedz
Feb 21, 2022Guide
Right now, I have more fundamental problems it seems. The Odroid (Pi-hole) wasn't working so I uninstalled everthing, got back to the normal state, then installed it again and again, the Pi itself can't resolve anything. I'm not sure what is going on.
I'll get back to you when I get past this hurdle.
Thank you for your time.
- plemansFeb 22, 2022Guru - Experienced User
Never ran pi-hole on an odroid. Ran it on a r-pi and in a docker container.
Have you ran pihole before?
Do you have your dns settings setup in the pi-holes settings menu?
You still need a dns resolver, it just filters it.
