FHCASE
Mar 21, 2021Follower
Setting up a static IP address CAX80
It does not seem possible to set up a static IP address on the CAX80 Nighthawk 8-Stream WiFi 6 Cable Modem Router. When you enter information into the page where you need to define the IP addresses...
Mar 22, 2021Guru - Experienced User
What Static IP address are you trying to set? WAN Static IP address?
