in2ndo
Aug 03, 2021Apprentice
Setting up openDNS with noIP.com
Excuse the cross posting but seems not many users with my new router nighthawk MK83. I'm setting up the MK83 to use OpenDNS. what I've done so far. I changed the DNS numbers on the router to the Ope...
Aug 03, 2021Guru - Experienced User
Please post bout this here in the Nighthawk MESH forum:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
in2ndo
Thank you for reply. I did post in that forum. But I guess not many use this router yet. So people that are familiar with it are almost none. I decided to post here. Because my question is more of the generic kind. Since this settings probably apply to a lot of other models. But thank you for your help.
- FURRYe38Aug 03, 2021Guru - Experienced User
- antinodeAug 03, 2021Guru
> Registered with OpenDNS and added my network with the IP [address]
> detected by OpenDNS.
https://en.wikipedia.org/wiki/Internet_Protocol
https://en.wikipedia.org/wiki/IP_addressThat's a start. I have a real domain, so I don't do this stuff, so I
know nothing, but, as I read the instructions, there's more to be done:https://support.opendns.com/hc/en-us/articles/227987787
6. Check the box to "Enable dynamic IP update." Be sure to apply
your settings at the bottom of the page.As I understand ("understand") this stuff...
DDNS is independent of OpenDNS. Your NoIP DDNS stuff should work
regardless of whether you use OpenDNS. DDNS lets you reference your
router's public (WAN/Internet) interface by DNS name, even when its
underlying IP address changes. For that to work, you need to keep your
DDNS provider (NoIP) informed when your router's public (WAN/Internet)
IP address changes. That updating job is done by an updater which is
built into the router firmware. (It's not hard for the router to notice
when its own WAN/Internet IP address changes.)
As you might guess from the fact that OpenDNS asks for your
(router's WAN/Internet) public IP address, OpenDNS associates your
custom settings with that IP address. If that IP address changes, then
your router will lose its association with those OpenDNS custom
settings.To keep your OpenDNS custom settings associated with your _changing_
public IP address, you need to keep OpenDNS informed of such address
changes. The NoIP DDNS updater in your router firmware doesn't do that
job; it doesn't tell OpenDNS anything.https://support.opendns.com/hc/en-us/articles/227987787 (again)
7. Learn how to keep your address updated. If you don't keep the
IP [address] updated, your preferences will not be applied, and
your statistics will not be collected - although you will still
be using OpenDNS.
8. Download, install and run the Dynamic IP Updater client on a
computer that is powered on 24/7, or started up daily and does
not leave your home network.From that, I gather that you can get an _OpenDNS_ updater which
_will_ do that job. But it won't be running on your router.But what do I know?
> [...] my question is more of the generic kind. [...]Perfectly reasonable. Advice to post in a desert is about as helpful
as an annoying animated icon.
