dgpach
Apr 11, 2019Follower
Setting up QoS on GS728TPP
Hi, I recently bought the above GS728TPP and need to set it up for Voip. It's behind a Cisco firewall. I'll need to create a VLan for the 24 ports, DHCP scope and QoS rules for ingress and egress....
antinode
Apr 11, 2019Guru
> [...] I recently bought the above GS728TPP [...]
Why ask about it in a "Cable Modems & Routers" forum? My quick
Forum search for that model found many more (than zero) instances of
this model at:
https://community.netgear.com/t5/x/bd-p/business-smart-plus-click-switches
Have you looked at the documentation for it? Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get some?
> [...] What level of technical proficiency is needed for this, [...]
I know nothing, but I might guess more than is needed to find an
appropriate forum to ask about it.
