Dexter65
Nov 06, 2019Aspirant
setting up Router R7000
Could not connect with my wifi so Bell suggested I get a router. Now nothing works. During setup procedure it asked for the SSID and password for both 2.4 GHz and the 5 GHz. I mistakenly entered m...
antinode
Nov 06, 2019Guru
> Could not connect with my wifi [...]
"Could not connect" _what_ "with my wifi"? "Could not" is not a
useful problem description. It does not say what you did. It does not
say what happened when you did it. As usual, showing actual actions
(commands) with their actual results (error messages, LED indicators,
...) can be more helpful than vague descriptions or interpretations.
> [...] Bell suggested [...]
Some company with "Bell" in its name is your ISP?
> [...] I get a router. [...]
What were you using before? What, exactly, was wrong with it?
> [...] Now nothing works.
See "not a useful problem description [...]", above.
> [...] During setup procedure it asked [...]
"it" being the R7000, or what?
> [...] I mistakenly entered my Bell network SSID and passwords instead
> of the ones on the Netgear Router, [...]
You should be able to configure the wireless-network SSID and
passphrase on the R7000 to any values you'd like, including the values
which you were using on some other wireless router. Keeping the old
values is probably a good idea, rather than a mistake.
> [...] The router came with literally no instructions. [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Beyond the basic set-up
material, look for the LED descriptions and "Troubleshoot". There
should also be an Installation Guide there.
> [...] I spoke for a long time with tech support at Netgear and they
> have no clue how to change it. [...]
"it"? The R7000 User Manual explains how to set the wireless-network
SSID(s) and passphrase(s).
> [...] Now when I try to connect devices to my wifi this Netgear page
> keeps popping up [...]
_Which_ "devices"? _Which_ "this Netgear page"? You do realize that
you're dealing with non-psychics who can't see what you're seeing,
right?
> [...] I can connect nothing.
> [...] The router is disconnected and in its box ready to go back. How
> do I fix this mess?
Do you expect it to work if it's in its box?
> bear in mind I am a 66 year old woman
You can read, though, right? If you expect to get help from people
who are not in the room with you, then you may need to supply some basic
information about your ISP, your equipment (old and new), how it's
connected, what you're doing, what happens when you do it, and so on.
If the material in the R7000 User Manual doesn't help, then you might
want to investigate local resources, rather than trying to get help
here.
- Dexter65Nov 06, 2019Aspirant
Are you fn kidding me that rude response? I do realize you are not in the room with me and I am thankfull for that. Thanks for nothing **bleep**
- antinodeNov 06, 2019Guru
> [...] Thanks [...]
You're welcome. And my thanks to you for your thoughtful (and
eloquently expressed) response. Sadly, it fails to provide any of the
requested information which was missing from your original problem
(non-)description, making provision of further assistance difficult.- Dexter65Nov 06, 2019Aspirant
As it turns out there is a defective WAN port. But thanks for your help. What a cowardly liitle incel bullying a senior citizen in that manner. Unbelievable. Your parents must be proud.
