Dexter65
Nov 06, 2019Aspirant
setting up Router R7000
Could not connect with my wifi so Bell suggested I get a router. Now nothing works. During setup procedure it asked for the SSID and password for both 2.4 GHz and the 5 GHz. I mistakenly entered m...
Nov 06, 2019Guru - Experienced User
Next time, please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
Dexter65 wrote:Could not connect with my wifi so Bell suggested I get a router. Now nothing works. During setup procedure it asked for the SSID and password for both 2.4 GHz and the 5 GHz. I mistakenly entered my Bell network SSID and passwords instead of the ones on the Netgear Router, The router came with literally no instructions. I spoke for a long time with tech support at Netgear and they have no clue how to change it. They told me to send it back to Amazon. Now when I try to connect devices to my wifi this Netgear page keeps popping up and I can connect nothing. The router is disconnected and in its box ready to go back. How do I fix this mess?
bear in mind I am a 66 year old woman
