mtiede's avatar
mtiede
Tutor
Dec 29, 2022
Should I be worried about my C7000v2 modem/router?
I wanted to have Spectrum update the modem/router.  (I think previously Time Warner did at least one update)
But now Spectrum (who acquired Time Warner) just says, "We don't update customer equipment".  And *I* can't update it.
So I bought a separate router (Synology RT6600ax) and I turned off the router portion of the C7000v2.  Things are working, but I have some concerns.  In particular (although I've been using this combination for several months now), I just got a "Threat Prevention" event detected Source IP 192.168.100.10 communicating to the Target IP 8.8.8.8 and saw signature "ET INFO DYNAMIC_DNS Query to a *.dyndns .org Domain ".
192.168.100.x is not my router's IP range.  I can't ping 192.168.100.x from inside my lan.  Where is this coming from?  Has some sort of DMZ been set up?  Is there something in the modem side of the C7000v2 that might be hacked?  How could the router even seen something from 192.168.100.x if none of the vlans are using that range?
I don't even know how to communicate to the modem now without doing a factory reset.
Should I replace this modem?  Any good suggestions for a new modem that would still let me continue to use the router?
  • michaelkenward's avatar
    michaelkenward
    mtiede wrote:
    ... I turned off the router portion of the C7000v2.
    How did you go about that?
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Connect Your Modem Router to a Router After Installation and Activation
    You may have done that already. I can't tell from your message.
    That will also explain how you can access the C7000v2 when you have put it into modem only mode. But there isnlt much that you can do in that mode. You can't control anything useful – that's down to your router – and you certainly can't update the firmware.
    In that mode, your router is in charge of your network and should be the defender of your security in the Internet. As a modem, the C7000v2 won't play the key role.
    Whether or not this is good enough is down to your level of paranoia. Most owners of cable modems seem to survive. They can't control their firmware either. Only ISPs can do that.
    What is the latest firmware version of my NETGEAR cable modem or modem router? | Answer | NETGEAR Support
    • mtiede's avatar
      mtiede
      Tutor
      I downloaded the documentation PDF when I first got the C7000v2 as I do with all my devices.
      per the documentation:
      Select ADVANCED > Administration > Router Mode.
      The Router Mode page displays.
      Select the No radio button.
      With this setting, the modem router works as a bridge and the router behind it obtains a
      WAN IP address from the Internet service provider
      Yes, that is where I started.  FWIW, I've been doing computer stuff since 1966.
      Support | NETGEAR
      As I believe I said, my router was already working with the C7000v2.
      As I understand it, I can NEVER update the firmware on this device.  By the nature of the C7000v2 that can only be updated by the ISP (who has specifically said they will NEVER do that either.  Thanks Spectrum)
      I know, and yet the 192.168.100.10 is referenced in an event and my Synology router has no VLANs in that range.  It also introduced a GUEST network that used the 192.168.0.x addresses and so I would be unable to access the C7000v2 via 192.168.0.1.  So I am just guessing that the C7000v2 may have introduced some sort of DMZ with that address.  Or something nefarious is going on.
      My ISP will not do that.
      What is the latest firmware version of my NETGEAR cable modem or modem router? | Answer | NETGEAR Su...
      Yes, that is the place that started this whole adventure.  I saw that my C7000v2 was several versions behind.  And I couldn't update it and the ISP won't update it.
      Got any other ideas about the origin of a 192.168.110.10 address?
        michaelkenward
        What does that mean? The origin of that address is the modem.
        You want to access it? (Why?) Disconnect everything from the modem, connect it to a PC and aim the browser at that address.
  • FURRYe38's avatar
    IF you got a new different router, the C7000 should be put in to modem only mode.
    • mtiede's avatar
      mtiede
      Tutor
      As I explained above, yes, I put the C7000v2 in modem only mode.  I'm trying to figure out what caused traffic from 192.168.100.10 that is not in the address range used by the router.
      • mtiede's avatar
        mtiede
        Tutor
        Also, if there some inherent weakness in using the C7000v2 modem (such as not being able to update the firmware), what standalone modem would be recommended and work with Spectrum.
