mtiede
Dec 29, 2022Tutor
Should I be worried about my C7000v2 modem/router?
I wanted to have Spectrum update the modem/router. (I think previously Time Warner did at least one update) But now Spectrum (who acquired Time Warner) just says, "We don't update customer equip...
mtiede
Dec 29, 2022Tutor
As I explained above, yes, I put the C7000v2 in modem only mode. I'm trying to figure out what caused traffic from 192.168.100.10 that is not in the address range used by the router.
Dec 29, 2022Guru - Experienced User
Only IP address that would be accessible is 192.168.100.1 thats the modems IP address for accessing that side of the units web page and when in modem model as well. Nothing else would be coming from the modem in modem mode.
- michaelkenwardDec 30, 2022Guru - Experienced User
That was my guess.
I didn't step in because I read the manual, which was misleading! (I suspect that mtiede did the same thing.) There I read:
"When your modem router is in bridge mode, use http://192.168.0.1 to
log in to your modem router."It is only by reading earlier messages here, that I knew that the manual can be misleading. And not for the first time.
That address is, of course, the IP address of the device in modem/router mode.
Manuals for some another cable modem/router does list "http://192.168.100.1".
- mtiedeDec 31, 2022Tutor
I tried to go to 192.168.100.1 today. I see that my new router blocked that access of that address.
"ET POLICY Reserved Internal IP Traffic"
So I allowed it, and I was able to login to the old Netgear modem/router.
I see the modem is active and the wifi is turned off.
And I can see how to turn it back into modem/router mode if I wanted to do that.
And since I see that the new router saw the traffic where I logged into the old modem/router, I'm back to the original question again. Why was the modem apparently trying to get DNS information using the 192.168.100.10 address? Why would it get DNS information at all?
- mtiedeJan 02, 2023Tutor
I happened to get another Surface Pro 9 and tried the same install steps I did with the first one. This time I did not get the 192.168.100.10 attempted access. So I'm back to not knowing why apparently the disabled router was trying to get dns information.
- mtiedeDec 30, 2022Tutor
"Nothing else would be coming from the modem in modem mode."
And yet, Threat Prevention sees traffic from 192.168.100.10 to 8.8.8.8. Which is what caused me to come here to ask about it in the first place.
I still have no clue what is going on there. UNLESS, something has managed to wedge its way onto the modem and is trying to do things there.
I also don't understand if it IS something on the modem, how was the router able to see it? Unless maybe ALL traffic goes through the router, even it started on the modem.
Or is maybe something in my network spoofing a 192.168.100.10 address somehow.
