ZeroC00l
Apr 30, 2017Luminary
Show HDD Size
Hello I have a USB 3.0 5TB HDD plugged into the back of the device, how do I get windows 10 to show how much space I have left on it? I wen't into the USB settings of my router and it don't show it. ...
DarrenM
May 02, 2017Sr. NETGEAR Moderator
Hello ZeroC00l
you would have to map the drive and look at it in windows.
DarrenM
ZeroC00l
May 02, 2017Luminary
Yes I did that, and I used that program, and it still doesn't show the size or how much is left on that drive, so do I just guess? :)
- DarrenMMay 04, 2017Sr. NETGEAR Moderator
Hello ZeroC00l
I will have to do some testing with my own external drive and I will get back with you.
DarrenM
- ZeroC00lMay 04, 2017Luminary
I am wondering if it's a premission issue with Windows 10? I don't know.
The thing is, I have seen videos and screenshots of others that where the admin page shows space, where mine doesn't, that's what's got me. The fact I cannot update my firmware that only my ISP can makes it even more annoying as they said they don't support my router and that I am on my own there. That I must contact Netgear to get my firmware updated. :(
