2george
May 13, 2020Follower
sleep or time out setting
Using a Temperatue wi-fi device that only comes on every 15 minutes to take ambient temp in my RV. The hot spot is timing out when no other device is detected to keep it on. Can you disable the sleep...
May 15, 2020Guru - Experienced User
The CM1100 modem doesn't have any router or wifi features. It's just a modem. IF your referencing this modem
Please reivew your wifi router or devices mfr support site for help and information.
Good Luck.
