jjparanurse
Jan 14, 2021Aspirant
Slow down when connecting router to CM700 modem
I have a CM700 modem with Comcast 600mbps cable intenet. My CM700 is connected to a TP-Link M4 Mesh System. My download speed from the router is between 85mbps - 118mbps. This is both on wifi as w...
Jan 14, 2021Guru - Experienced User
so you're getting full speed when directly connected to the modem?
Seems to indicate the modems doing its job.
I'd be looking closely at the cable from the modem to the router/routers.
- jjparanurseJan 14, 2021Aspirant
I did try a few different LAN cables. I was thinking the same thing, but it still doesn't explain why my laptop gets full speed since I used the same cable to connect my laptop as I use for the routers. I did order a new CAT8 cable today to see if that would make a difference.
I wasn't sure if there were settings in the CM700 that would slow the speed when connected to a router versus connected directly to a computer.
- plemansJan 14, 2021Guru - Experienced User
there's not. But some devices might be a little more tolerant of a bad cable or a cat5 cable vs cat5e or > .
- jjparanurseJan 16, 2021AspirantIs there a setting in the CM700 modem that would slow the speed when talking to the router versus talking to the laptop?
