jjparanurse
Jan 14, 2021Aspirant
Slow down when connecting router to CM700 modem
I have a CM700 modem with Comcast 600mbps cable intenet. My CM700 is connected to a TP-Link M4 Mesh System. My download speed from the router is between 85mbps - 118mbps. This is both on wifi as w...
jjparanurse
I did try a few different LAN cables. I was thinking the same thing, but it still doesn't explain why my laptop gets full speed since I used the same cable to connect my laptop as I use for the routers. I did order a new CAT8 cable today to see if that would make a difference.
I wasn't sure if there were settings in the CM700 that would slow the speed when connected to a router versus connected directly to a computer.
Jan 14, 2021Guru - Experienced User
there's not. But some devices might be a little more tolerant of a bad cable or a cat5 cable vs cat5e or > .
