jjparanurse
Jan 14, 2021Aspirant
Slow down when connecting router to CM700 modem
I have a CM700 modem with Comcast 600mbps cable intenet. My CM700 is connected to a TP-Link M4 Mesh System. My download speed from the router is between 85mbps - 118mbps. This is both on wifi as w...
Jan 16, 2021Guru - Experienced User
no
jjparanurse
Jan 16, 2021Aspirant
Still doesn’t explain why I lose the speed when connected to a router. I thought it might be the router but I’ve tried two different routers with the same results.
- plemansJan 16, 2021Guru - Experienced User
So the modem gives full speed when a computer is directly connected to it?
Then its getting the speeds and outputting them.
It could be a cable thats having issues, the routers, or some combination of that.
