legendarby
Mar 03, 2019Aspirant
Slow internet, High amt of correctables/uncorrectables, no ip when hardwired
Hi,
I'm getting super slow internet speeds and I have a high amount of correctables/uncorrectables. I used to have a CM700 and I thought the PUMA chip was causing slow speeds so I bought a CM60...
- Mar 07, 2019
Those timeouts typically indicate an issue with your ISP. You will want to contact your ISP and have them send a tech out to check out the lines in your area.
DarrenM
legendarby
OP here again,
I'm also getting a bunch of these errors:
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC
MDD message timeout;CM-MAC
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC
I don't know if thats relevant to the problem but it was happening every couple min for hours.
- DarrenMMar 07, 2019Sr. NETGEAR Moderator
DarrenM
