legendarby's avatar
legendarby
Slow internet, High amt of correctables/uncorrectables, no ip when hardwired
Hi,   I'm getting super slow internet speeds and I have a high amount of correctables/uncorrectables. I used to have a CM700 and I thought the PUMA chip was causing slow speeds so I bought a CM60...
  • DarrenM's avatar
    DarrenM
    Mar 07, 2019
    Those timeouts typically indicate an issue with your ISP. You will want to contact your ISP and have them send a tech out to check out the lines in your area.
    DarrenM
