rainbow_brite28
Feb 29, 2020Follower
Slow Network Drive HELP!
So i recently purchased the netgear C3700v router specifically for the USB port on the back, I also got a Western Digitial easystore 12TB harddrive. I connected it to my Netgear harddrive via readysh...
michaelkenward
Mar 01, 2020Guru - Experienced User
What you actually own is a cable modem/router.
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
I am surprised that you got a 12TB USB drive to work on ReadyShare. That is twice the size previously reported as working. Most people find that much above 4TB causes problems.
The size may explain this bit:
It connects to it fine and everything but when I try to read or write files to the drive it is sooooooooo slow! Viewing takes about 10 seconds for even the preview to show up when I click on it.
You are asking a lot of this rudimentary network technology. For any heavy duty stuff, you should think in terms of proper Ethernet.
One problem with a cable modem/router is that you have no access to the firmware. That is in the hands of the Internet service provider. So you can't even contemplate third party firmware that might make things a bit better.
